Originally Posted by adrummingdude
Thanks Ryan. To clarify (and I think what the other poster’s question is), these springs will lift a Pro 1.8 additional inches, bringing the total lift to ~2.8” compared to a stock SR5. Correct?
If so, I know a lot of guys with a 3” front lift are running aftermarket upper control arms to be able to get their castor in spec, and many of them are also dropping their front diff. However, I don’t know if the control arms on the Fox outfitted Pro are already different than the other trim level trucks.
I really would like a set of these springs as I’ve had Eibach drop springs in the past and have liked them a lot... but If it’s going to come along with a new rabbit hole I’m not so sure.
I know exactly what he’s asking and I’m trying not to answer it and confuse everybody. There’s just no reason to compare it to non-PRO. You’re already getting worried about arms because of it even though I said upper arms are not needed ;)
Everything you are concerned about is checked during our R&D process. If you need arms, diff drop, etc etc it will absolutely be mentioned waaaaay in advance. For 1.8” of lift it’s not necessary.
Hope that helps
