Originally Posted by duffdog
Its just not going to happen. Nobody has ever installed 33's on a 4runner and not had them rub on the frame when off roading. Forget the sway bar and body mount, even after all of that is done the 4runner can turn so sharp that the actual frame hits the tire. There just aren't people who can say that they have done it without rubbing. Even if you are doing something as simple as going up a driveway and turning, either the tires will rub or you do not have 33's, its that simple. 285's are not 33's, they are slightly smaller. 33's are 33x12.5x17.
If you are bored, go ahead and type in the tires size to see the difference here:
Tire Size Comparison
I got 255/80/17=33" all i did, just moved front fender liners forward and removed front mud flaps, oh 1inch daystar on the front. I offroad my truck all the time. If there is any rubbing it is negligible.
Sent from my Redmi 4 using Tapatalk
