If you can get it into the pan, I don't think it will go anywhere and you are safe. Based on your oil flow diagram, if the oil pump does suck it up, it's going to get caught on the strainer. Otherwise it will just slosh around in the pan.
If it does break up into bits and get past the strainer...they should get caught in the filter. The oil pump won't even notice any little plastic/foam bits.
2002 4Runner 4WD SR5 - Original Owner
