Originally Posted by xtremewlr
You aren't completely removing the body mount so the chop would not jeopardize the structural integrity nor take away from the extremely remote chance that it could deflect a wreck away from the passenger compartment. If anything, the new material that is added from the chop would make it stronger.
It honestly shouldn't cost too much if you find a welder that will do the work. It's a simple cut and weld. Relentless Fabrication sells a pre-cut plate just for this work - 2003-2018 4Runner Body Mount Chop Plate – Relentless Off-Road Fabrication
If you buy those plates and do the cutting yourself (angle grinder and cutoff wheel), they should only charge you maybe $20-$30 to burn the plates on. Then just rattle can the new metal so it doesn’t rust. It’s not a hard job whatsoever, just find someone who isn’t going to gouge you.
