Originally Posted by doofenshmirtz
So I’ve got some play in my u-joints at each end of the driveshaft. I think some “spirited driving” after doing a sea foam treatment may have weakened/loosened them mine also have no zerks, so I can’t grease them to see if that would help.
I have the 2WD drive V8, so I’ve got the driveshaft that slips into the transmission rather that one with bolted on flanges at each end, like I think the 4x4 does...
Can I avoid any fluid spills by removing the u-joint at the transmission end and leaving the yoke in the transmission? Or will it just slide out without anything holding it in place?
I have V6 2WD and it doesn't have zerk fittings either. I pulled a driveshaft out of the trans on a standard transmission Ford like that and when I put it back in it started to leak at the rear seal. I wonder if it would be a good idea to replace the rear seal while the driveshaft is out.
