View Single Post
Old 01-09-2020, 04:20 AM
montijo505's Avatar
montijo505's Avatar
Your V6 doesn’t need the timing belt (V6 actually has a chain not like the V8) and water pump replaced unless they fail. Unless it’s giving you problems I could see you getting to double your current mileage relatively problem feee as long as you keep up the maintenance.
The only things you didn’t mention worth looking into are coolant flush, has the transmission fluid ever been swapped/changed, rear diff fluid ever changed, any known issues?
As for suspension if you don’t plan to off-road you can just replace with OEM grade components instead of dumping money on a lift. Something like the quick strut options on rock auto.
