Originally Posted by rooneyy
No question is a dumb question! Where would the ground be? I'd like to check.
It'd be the black wire coming out of the back of the H/U. It can either be run back to the chassis ground via the wiring harness or you can find a grounding location near the H/U behind the dash.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes |
GSport 2.5" Cats | DT Y-Pipe |
Magnaflow Cat Back |
2.5" Vibrant Ultra Quiet Resonator
