Originally Posted by Bdnewyork
You can register your VIN on the Toyota Owners site and access original vehicle build specs, which at least in my case, indicated original tire size as well as additional useful info:
Logged Out My Vehicle Page | Toyota Owners
Or just have a look at the driver's side door jamb sticker, which shows original tire size and pressure info.
Hey thanks bdNY...laughing here, just found that this morning and reading my build sheet. I've been calling my truck a "base" model, they refer to it as the "standard" model. I knew what the original tire size is...I'm trying to figure out the best way to correct the speedo after I install the 265/70/16 tires (also stock)...without a big hullabaloo. Build sheet says my truck does NOT have ABS...so it would seem to me that there might be a chance that all I will need would be the correct speed sensor for the transmission / tire size combination. Keeping my fingers crossed...
