Originally Posted by TonyB66
Andy, thanks for the feedback. Installing these now actually. Did you happen to grease them? Grease was not supplied in the Energy Suspension kit, which I think you also got. I had planned to use grease and woke-up last night realizing I forgot.
I had found before that a good grease can not just prevent squeaks, but also help with vibration dampening. I have a tub of ES's Formula 5 that I'll be applying. Damn sticky stuff, but it always worked quite well for me...
I was hoping to provide a good article on the topic, but can't find it now.
I coated them all. Used everything I had. they don't squeak, yet.
I just picked up a stock 98 vs re-done 97
when I say cold I mean 15 F or lower
98 stock still has OEM shocks/springs/mounts rides nice even when cold.
97 redo has eibach and all poly, when cold it rides like a board.
a lot of variables could contribute to this... links, bushings... so it's hard to tell I guess really.
all the engineering docs rave up and down about poly, and how it's so much better in every way. The more poly I use the less I like it.
