Originally Posted by jeffsGT7
Hoping someone can help us here.
2009 SR w/90k
Issue is that Heat is on or off (if fan is on and 65+ degrees it's ON, move the temp to LOW is it's OFF).
Fan works great, A/C is fine, just a PITA managing heat (esp. here in Michigan).
Thanks
When you say "LOW" are you saying lowering the temperature setting lower than 65 degrees via the center control or pushing LOW on the control on the left?
