I'm not 100% sure because your truck is an auto. But I do know my 97 2.7 2WD manual came with a 3.73 rear end, if that's the case for you as well one of the the cheapest and certainly the best way to fix the speedometer difference would be to drop in a good 4.10 differential.
They can be found incredibly easily here for 100$ and can be swapped out in under an hour if you know what you're doing with only regular hand tools and a tube of RTV.
Besides fixing the speedo readout, this has the added benefit of fixing the gearing being thrown off by the larger tires and putting your powerband and shift points right back where they're designed to be.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
