1st Gen - Rear Window Key Cylinder Stopped Turning Left (Up)
Hi guys,
A few days ago, I noticed I could no longer turn the key in the rear window lock cylinder to the left to put the window up. Down/right is fine. The interior front console switch works fine in both directions.
I can't recall when it was working, if the cylinder always turns left, and the window won't go up (i.e. when the top is off releasing that bolt switch), or if that switch prevents movement of the lock cylinder completely?
Basically, is this a physical problem or some weird wiring issue? Not sure where to start here.
