Originally Posted by 4Tuitous
Checked my build sheet on the Toyota Owners Spec. site...my truck is non-ABS. As per your earlier reply, do you think it possible that there might simply be a correct speed sensor for the 2WD auto trans. / 16" tire combination?
I think it is pretty unlikely that there were 16" wheel trucks built without ABS - almost all had ABS. Just to verify, check your engine bay - this is where the ABS actuator is:
You can still use the Dakota Digital interface, even without ABS, you just have to wire it in a different location. Or you can leave the speedo signal alone and put in 4:10 diff to fix it (no need for a calibrator).
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
