Originally Posted by AndreFBR
O know it has been a long time since you have posted this topic, however could you figure out a way to install an aftermarket cruise control on it?
I have a diesel hilux surf (KZN185 with a KZ-te engine) which despite has a electronic controlled diesel injection does not have a cruise control.
I'm wondering if its need an additional module to instal an aftermarket on it or just a cruise control stalk would work.
Originally Posted by T4R2014
Is it even ECU tied? On a mechanical throttle, all it appears to be is a servo with a cable that holds the throttle butterly to a position.
Guys, here are pics of how I installed the actual CC actuator behind the air filter box.
Hope this makes it more clear. If you exchange the accelerator cable with a different length, you can install the actuator in any available free space. I had space behind the filter box, so that's where I mounted it.
Also make sure when you attach the cable to the throttle, that is has no slack, otherwise when you set it at certain speed, it will jerk the car every time it pulls to accelerate or lets it go to decelerate.
You can see where I ran the electrical harness into the cab- thru a hole in the driver's side of the firewall.
"Sadly, unlike the Bill of Rights, the UDHR has no 2nd amendment, rendering it useless. Remember that."
X-UN T4R2000 TDI3000, 1KZ-Ti, M/T,CDL,RDL3.9
https://www.toyota-4runner.org/garage/9344
https://www.toyota-4runner.org/membe...lbums-rig.html
taharateq.com
