View Single Post
Old 01-14-2020, 02:44 PM
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
  • Clean MAF (and replace the o-ring if you like).
  • Clean throttle body (off the truck preferably, but probably a waste of time at 60k).
  • Brake fluid flush. Check all the bleeder caps are still there.
  • Power steering flush.
  • Front diff drain and fill.
  • Transfer case drain and fill.
  • Rear diff drain and fill.
  • Coolant flush.
  • Replace radiator cap (might as well).
  • Replace gas cap gasket if you feel like.
  • PCV valve (wouldn't bother at 55k).
  • Check serpentine belt.
  • Check and adjust parking brake.
  • Grease drive shafts.
  • Lube hinges and spare tire carrier.
  • Transmission fluid replacement.
  • Replace rear diff breather.
  • Clean and grease battery terminals.
  • Replace air filter.
  • Replace cabin filter.
  • Put anti-seize the skid plate bolts.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
