Originally Posted by VernySanders
I'm just going to do it all! I never shy from proper preventative maintenance! Neither do you I'm sure that's why I love this forum! Honestly best online community for any vehicle that I've ever come across.
I’m going to say this......
As part of our collective and sharing knowledge, shotgunning the problem by replacing a bunch of things at the same time may fix it but not define what was the actual problem from a troubleshooting perspective.
You can still replace all the things you want but do it one part at a time to figure out what’s causing the problem.
There are a bunch of extended crank threads without any solution. My Ex’s 97 Puppy Hauler would start normal in about 2 seconds on the starter. Then on occasion it would take longer. 5 or so. It’s not my problem anymore.
If it was my problem I’d do the IAC first since at times I caught it idling high. And cleaning it would fix it.
Second I’d watch fuel rail pressure to see if a injector was leaking and bleeding off rail pressure.
Third would be fuel filter (in my case it’s only two years old)
Fourth would be fuel pump.
I do not think our fuel pump starts running until it’s put to start. American rigs will run the fuel pump at ignition on for a few seconds and after it detects engine run it will keep it running.
