Originally Posted by 4Runner168
So I have had my 2020 for 3 months/5000 miles already, had 2 questions regarding the following:
1) My brakes squeak a lot especially during humid/wet days if the vehicle has been sitting for a while, the dealer said that it was normal and the noise goes away after a while but I just find it to be really annoying. My next service appt is not for another 5K miles which is about 3 months out, any suggestions on how to resolve this squeaking issue short of taking it back to the dealer again?
2) Rear glass defroster doesn't seem to do a very good job, it only clears like a half inch wide strip for every line that goes across the glass. Is this normal for the 5th gen?
Thanks
The defroster should clear the whole window, but it may take some time. If it never clears then you'll want to raise it with the dealer. See below about your brakes.
Originally Posted by rotorwind
My 2020 breaks squeak too. Usually In the morning when cold and brakes applied lightly. I have 1200 miles on it. Hope it goes away
Squeaky brakes are a fact of life with all cars. When it is humid/wet and the car has been sitting, surface rust will form on the rotors. When you apply the brakes they will squeak.
Perfectly normal. You didn't break anything and the brakes will still work as intended.
