View Single Post
Old 01-16-2020, 12:21 PM
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Originally Posted by pinemind View Post
Hi guys,
A few days ago, I noticed I could no longer turn the key in the rear window lock cylinder to the left to put the window up. Down/right is fine. The interior front console switch works fine in both directions.
I can't recall when it was working, if the cylinder always turns left, and the window won't go up (i.e. when the top is off releasing that bolt switch), or if that switch prevents movement of the lock cylinder completely?
Basically, is this a physical problem or some weird wiring issue? Not sure where to start here.
sounds like an issue with the switch itself. you may try some lock cylinder lube, or compressed air. if that doesn't work, you will probably need to replace it.
the last time I checked, they were fairly expensive.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
