Originally Posted by 2112 R
+1 for interest in this. Installing a 3" rear lift in a few weeks
The height won’t really matter. It’s your shocks that will be the limiting factor. So if they are 25 3/4” - 26” fully extended measured from center of lower eyelet or bolt up to the top of the lower bushing at the pin top mount on the frame. If you can get that spec before hand then you should be good. I’m pretty sure no one really makes anything longer then that anyway for the kdss because no one has been able to pull more then that prior to this part.
Sonoran steel zig zag bar is maxed out at 25 1/2”. And any more with that setup the kdss will invert itself. Mine still has more to go.
