KDSS Lean?
I went down this path in 2016 after installing Icon Stage 6 and getting some major KDSS lean. I tried all the KDSS tricks like bleeding, calibrating, etc. Nothing helped, still leans. The next step was making extension blocks like these. I couldn't figure out the optimum block height so I settled on 50% of the lift height, 3" * 0.5=1.5" Then I lost access to my CNC and moved it to the back burner. I'm curious about your block height and underlying calculations. Do you think this would fix the KDSS lean? My research and understanding of the mechanism suggest it should help but I never completed my blocks to test it out. By the way, my Icon track bar still rubs. I'm so glad you made this work and are going to sell some. I'll buy a set!
2013 TE: Build Thread Adventure Thread CBI Front and Rear Bumpers, Bud Built→(Beefy Sliders, Aluminum Skids, Diff Skid), Custom Grille w/ Rigid D2 Driving, Warn Xeon 10, Icon Stage 6, Gobi Stealth, Safari, ARB Front Locker, and lots of fun custom stuff from Ascend Overland
2005 LJR: Clayton 5.5, LS swap, NV4500, Atlas 4-speed, Revolution Gears, Chromoly and RCV shafts, Reid Racing Knuckles for Dana 44, ARB lockers F/R, GenRight tube frame, Ascend Overland 48" Drawers
