So my truck likes to pull to the right when braking hard on un even terrain. I was told the calipers were bad based on assumption and research. I replaced the rotors pads and got OEM used calipers. Well it still pulls to the right when braking hard. Did I just buy another bad caliper ? Haha. I noticed the inner cv axle boot is torn. I don’t know if that has anything to do with it. I also have another question about the horn and cruise control. I replaced the clockspring thinking that was the culprit. The horn worked for a little bit and than stopped working and blew a fuse. The PO installed reed horns so my guess is a bad ground?? I’m stumped
280k 4x4
