Real Name: Tim
Real Name: Tim
You mentioned nothing about the rear brakes. Uneven braking in the rear can make your rig pull. Jack up the rear end of your rig, pull off the left rear tire and then remove the drum. If a rig pulls to the right and the rear brakes are the cause, it will be a problem with the left rear not grabbing as effectively as the right rear. The reason why I know this is it happened to me. It's how I figured out I had a leaking rear axle seal. My brake shoes were coated and gear oil and not grabbing well.
