Probably want to go check her car for the correct level too! Set them at the max cool level on the bottle.
Sounds like it just overflowed because the tank was overfilled. There needs to be significant expansion room in the tank due to normal volume changes while driving. The max heat in the system happens right after shutdown, so that's when you are most likely to notice it.
The engine bay always seems hot during/after running - I wouldn't take a 'feeling' of it being hot as a problem.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
