View Single Post
Old 01-17-2020, 04:56 PM
SnoRnR's Avatar
SnoRnR SnoRnR is offline
SnoRnR will become famous soon enough
SnoRnR's Avatar
Originally Posted by jhguth View Post
1) With the charger mounted directly above the battery (so circuit length <5'?) redarc recommends 6AWG for 25A? That is overkill. Or are you asking about wire to the solar panel? I'd use the fuse they recommend, they're not that big and you can get in-line MIDI fuse holders.
They recommend 6AWG <5M and 8AWG >5m but I only have 1 cable under that. I could use 8 but some runs would be close.
2) I think 10 AWG is the most common I've seen used for the fridge, I ran 8 AWG because I had it. The pre-made ARB and Dometic wiring use 10 AWG for example.
Awesome
6) I was not happy when I tried to fit 8 AWG wires in the windshield trim, I ended up going through the rear instead.
Ok maybe I will run 12 or 14 for lights on roof rack. Leave the 10AWG for RTT power and solar as a short length that I can connect when needed.
7) they make through panel connectors you can use, I have a place to plug in 120V for onboard charging but you could use a similar spot for solar. I have no idea what wire gauge this is so I'm not recommending this product specifically, but this is the type of socket I am talking about: https://www.amazon.com/dp/B0031BOTFC..._eiHiEbRQ7QJK2
and here is my suggestion for where you could install it (ignore the red circle i was showing the antenna mount). The plastic panel pops right off and you can drill through it, it's cheap to replace if you change your mind later:
https://i.imgur.com/B3K4UK6.jpg
Is that a NOCO? I have seen them for shore power. Guessing I could just use the connector you have with an Anderson on the other end.
2019 TRD PRO
Gobi Stealth No-Rise / C4 Fab Sliders / Xenon Depot HID Low LED High / Goose Gear Drawer & Sleeping Platform / RAGO MSP / ARB Dual Compressor / Shrockworks Dual Battery / ARB Differential Breather /
SnoRnR is offline   Reply With QuoteReply With Quote
