Originally Posted by MikeyMTBs
It was quicker than getting the dremel out and butchering the Morimoto bracket to try to get them to fit.
1. From the OEM fogs, unscrew the adjustment screw, look inside the housing and pinch the tabs to let the screw fully back out. I used a small pair of needle nose pliers to pinch the tabs on the screw.
2. Lift the OEM bracket at the pivot point on each side and it will pop off.
3. On the Morimoto brackets, remove the adjustment screw and spring.
4. Remove the brackets at the pivot on each side.
5. Pop onto the OEM bracket onto the Morimoto pivots in the same orientation.
6. Screw in the white plastic adjustment screw from the OeM bracket.
7. Reinstall with no modification and enjoy having perfect fit with no gaps fog lights.
Wow, easier than I expected. Thanks man! How easy was it to adjust them afterwards?
