Originally Posted by filoufil
Here's a couple answers:
I use an anderson connector with my ARB wiring kit. The connector size you are looking for is an SB50 and they have connector for wires as small as 12AWG. Take a look at the datasheet and pick the appropriate connector for your wire guage: https://www.mouser.ca/datasheet/2/22...50-1652903.pdf
I would go with 2AWG if that is what is recommend for the length and amperage. Unless you predicted your build and know for sure you would never use 125A.
What you are talking about is HDPE, not HTPE. 1/2 inch is plenty strong, I did mine with 1/2 inch. I would use 3/8 if I was to do it again.
Here's my setup where you can see a picture of my bracket: Project - Dual battery setup
As stated above, you need a 34-PC1500. Refer to this diagram and take into account that the terminals are towards the firewall (updside down compared to the diagram from Odyssey): https://www.odysseybatteries.com/images/1500terms.gif
Awesome. Thank you. Yes, I meant HDPE. I will go with 2AWG. I know the Switch pro is fused at 125A but I doubt it ever draws that. I will only have lighting and basic 12v stuff connected to it. The biggest load will probably be a lighting bar or 2 x Baja SP6's on the front bumper when I get it.
