Originally Posted by phattyduck
If you want do do that, connect the ground wire (white-black) from your current corner light to the turn signal positive wire instead of ground. It will flash with the turn signals when the lights are off and opposite the turn signal when the lights are on, like this (ignore the switchback main turn signal, focus on the corner light):
YouTube
I also put in a very bright LED corner bulb to help out with brightness there.
Charlie,
I like this approach. Can you help me understand from a wiring perspective why it works that way?
Which LED bulb did you use?
