Originally Posted by Ed_C
The wiring drawing is correct there. I was always under the impression that the turn signal power was grounded when the bulb was off, but 'grounding' through the turn signal filament makes sense. I still have all stock rear incandescent lighting, which would function for that purpose with the LED front lighting.
What LED are you using in the corner light? So far the 194 and 921 styles I've tried are polarized. I was originally going to do the "crossfeed" method you've done but didn't want the bumper signals to alternately flash with the corners.
I used stuff from superbrightleds. I found the order in my email history:
The turn signal is an 1157 switchback, PN: 1157-AW60-SA-CAR
(that is what fits in the turn signal used on the Shrockworks bumper, I don't think it will work in the OEM housing)
The corner light is a non-polarity sensitive 194, PN: 194-AHP5
I just chose the brightest non-polarity sensitive 194 compatible bulb they had in amber.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
