View Single Post
Old 01-20-2020, 08:44 PM
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by phattyduck View Post
Its a "any manufacturer that cares about batteries" thing. Battery chemistry changes with temperature, and requires a lower voltage for correct charging (instead of overcharging) with higher temperatures.
Be glad we don't have even more modern alternator systems that turn off completely under 'low load' situations.
Yup. Lead acid are fully charged below 12.6 Volts and the range for engine running is 13.7 to 14.7. Anything higher then 14.7 volts are a fully charged battery is actually cooking the cells.
The bummer is that 12.4 is when a car battery is dead. Below that you are sulfating off your conductive plates. so 12v is not a good reading at all.
When it gets cold in the winter. I sometimes hook a 2 amp charge over night on the vehicles I am driving. That way if they were down a little the charge will bring them back up to full state.
People do not fully understand that the alternators on most modern cars are only for maintaining a charge. If you accidentally drain one down. You really should charge up up for 12 or 24 hours a a low amp charge. :-)
