View Single Post
Old 01-20-2020, 09:35 PM
ddnww's Avatar
ddnww ddnww is offline
ddnww is on a distinguished road
ddnww's Avatar
Originally Posted by Dropzone View Post
V6 & Turbo diffs have 4 spiders gears in the rear third
4 Cyl diffs have 2 spider gears.
I don't actually get what you mean thicker rear end..been messing with these POS's for 34 years
Below pulled from Pirate FAQ
Stock Toyota front axle measurements for comparison:
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, SA Hubs
58.25" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, IFS Hubs
63.5" wide, (set up for coil springs) 90-97 FJ80 and FZJ80 Landcruisers
'86-95 IFS front end is about 58.5" wide
'93-98 T100 IFS front end is about 65" wide
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-up Tacomas/4runners
66.75" wide, '93-98 T100 trucks
Thank you, ok so the difference is 2 pinion vs 4 pinion on the 4cyl to 6 cyl rear ends.
I know the 86-95 is 58 inches wide at the flangeto flange aka wheel mounting surface, but I need the measurement from the back plate to back plate, I believe it should be about 50 inches.
2007 Driftwood Pearl SR5 V6 4x4 /MB Wheels TKO 17x8.5 -6mm/ Hankook dynapro mt2 285/70/17 / bilstein 5100s -1.5 daystar rear spacer lift on moog fj coils / 1" Toytec body lift / ddm hids / interior leds / reverse light led / vsc - atrac disable mod / limo-30% tint/ rear diff breather mod / rola vortex roof rack / hanma 30" LED lightbar / kenwood ddx373bt w backup camera / ppi p900.4 / sundown sax1200d sa8d4v1.5 / diamond audio d6 comps / SPPC black halos
ddnww is offline   Reply With QuoteReply With Quote
