View Single Post
Old 01-21-2020, 03:19 PM
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
ICON is one of the Most Popular Suspension options for Toyota.
This includes Tundra, Tacoma, FJ Cruiser and 4Runner.
We receive a lot calls, emails and PM's from both T4R members and non-members regarding
Stage 1 vs Stage 2 Complete Kits.
The cost for Standard and Extended Travel coilovers are the same, but Extended does require
the addition of an Aftermarket Upper Control Arm. This added investment is worth taking into
account for your Daily Driver and Weekend Warrior needs.
These adjustable coil-over shocks have proven their strength and longevity for years.
Standard and Extended Travel coilovers offer the best ride quality and handling. They
increase suspension travel and dramatically increase the capabilities of your 4Runner's
front suspension.
Extended Travel Coilovers are meant to be installed with an aftermarket UCA to ensure
the proper amount of wheel travel and to prevent premature ball joint wear.
ICON Coil-Over’s come complete with all the hardware necessary to complete the installation,
as well as, a sway bar relocation bracket kit to adjust the location of the sway bar to clear the
larger shock.
Technical Specs:
- Adjustable ride height from 0" - 3.5"
- Race shock piston with flutter stack compression valving
- Kit Includes Sway bar relocation brackets
- Cad-plated threaded body / Extreme Weather Plating Option Available
- Billet aluminum upper mount
- 5/8" PTFE-lined spherical bearing
- Completely re-buildable
- 2.5" shock diameter to prevent overheating
- Chrome-silicon spring
- 250 PSI nitrogen-charged internal reservoir
- Made in the USA
- Nitro-steel shaft will not chip or rust like chrome shafts
Recommended tire size 285/75R16, wheel 16X8 with 5" back spacing.
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
