Originally Posted by mesooohoppy
just the drivers. i was told i need a 2 ohm resistor to turn the light off. im trying to avoid cutting off the plug if at all possible.
You should be able to use this:
Internal Error
Just stuff the leads in the connector. Protect it from grounding out, zip tie it in place or similar, and you'll be all good.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
