Originally Posted by MikeyMTBs
Before I removed the OEM fogs, I marked the cutoff line on the wall in my garage. For adjustment of the Morimoto fogs, I reinstalled the bumper but didn’t attach the fender liner. It’s easy enough to lay under the front of the vehicle, flex the fender liner back a bit and reach up with a Phillips head to adjust. The big OEM adjustment screw makes it super easy. That took no time at all.
I adjusted the passenger side slightly higher than the driver’s. Buttoned it back up and it’s been perfect.
I was pissed with the fitment of the Morimoto fogs before swapping the brackets. I had ground the brackets down to nubs with my dremel and they still didn’t fit for shit. The screw side of the bracket has to be enlarged to fit.... it’s just not acceptable.
The fit with the OEM brackets makes these fogs really standout.
I'm having a very difficult time removing the leveling screw form the OEM set up to transfer the bracket. I read your reference to using pliers, but I'm not sure I understand how that should be working. Any clarification would be much appreciated.
Stock Morimoto bracket fitment is terrible!
