Originally Posted by meepmeep
So, I am replacing my forward bulbs with Xtreme LED Pro units. The H11 low beam units installed fairly easily. However the high beam 9005s will not twist into place. It seems that the three tabs are too thick to twist into the slots. I have pressed forward as hard as I can. What am I missing? Do the tabs need to be modified? Any suggestions appreciated!
I've run into this before - quick fix: check the thickness of the rubber gasket on the new bulbs compared the old ones. If the old ones are noticeably thinner I'd swap them and see if that helps.
