Originally Posted by Clemintine
Hey All,
I just bought my 98 and love it. 5 speed, 3.4L, 215K, in excellent condition.
Like all things good though, I will be starting to slowly build her up. I have to save a little, but first things first.
Tires. I have the stock 16", and want larger tires for off-road. All Terrains. I don't really know how the tire sizes work though (yes...groan for sure), but I thought if there is a place to start asking, it's definitely here.
Any of you peeps have thoughts on this? I don't plan to do a body lift, but I do plan on at least a 2" suspension lift. Also thinking of installing 2" wheel spacers.
So tires first. Is there a cap to the size I should use (for over-sized), and concerned about wheel rub.
Any info will help. Thanks.
Welcome to the forum. Replace the lower ball joints if they haven't been replaced before.
Suspension lift on IFS does not help clear tires. Body lifts, larger bumpstops (limiting travel), messing with the caster to push the tires forward or cutting whatever the tire hits will clear tires on IFS.
The first number on a metric sized tire is the width in mm. The second number is the ratio of sidewall height to width. And obviously the third number is wheel size in inches.
For a 265/70/16 tire, the width is 265 mm (10.43 inches). The sidewall height is 70% of the width so 265 mm x .7 = 185.5 mm (7.3 inches). The overall diameter is then sidewall height times 2 plus wheel diameter. Obviously do this in inches so (7.3 inches x 2) + 16 inches = 30.6 inches diameter. It's common just to round up (31") on these metric tires.
Increasing backspacing by using spacers or buying aftermarket wheels will make tire rub worse but can be necessary depending on tire size. Wider tires will rub more as well. As a general rule for the common 16" tire sizes:
- 265/75/16 (~32" tire) shouldn't rub on stock wheels, but still might hit the back of the wheel well.
- 285/75/16 (~33" tire) will probably require trimming of the wheel well liner and cutting/hammering the pinch weld. The sidewall of the tire may or may not clear the UCA on stock wheels.
- 315/75/16 (~35" tire) will require tubbing the firewall.
If you want zero to minimal work for tire clearance go with 265/75/16 and no spacers. If you want bigger tires and/or wheel spacers or aftermarket wheels just be prepared for more work.
Fishwerks' Photo/Build Thread 2000 SR5 l White on White l 35s l Supercharged
2010 Trail Edition l Salsa Red Pearl l Stock
Instagram
