View Single Post
Old 01-23-2020, 12:23 AM
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Originally Posted by gn9119 View Post
At the risk of being accused (rightly perhaps) of being lazy/cheap, i have a stuck piston on left rear caliper on '06 V8. Could i just put a gen 5 caliper on that side and leave the original on the right rear. Wear on that side is even, but the left side's inner pad is worn down about to the shim while the outside pad is fine.
I'm putting new rotors and pads across both R/L rear and need to address the stuck caliper one way or the other. Was going to just stick a 4th gen on there but read about 5th gen swaps so here we are...
No, you should always do brakes in pairs. So if you replace one with a Gen5 caliper, you should replace both with the same on that axle, be it front or rear.
xtremewlr is offline   Reply With QuoteReply With Quote
