Did you follow the instructions on the master cylinder reservoir for how to properly check the fluid level? On the 2001-2002s with the hydraulic brake booster you need to pump the brake pedal ~40 times with the truck off to purge the pressure from the accumulator before checking the level. Once you turn the truck on and the system "pumps up" the fluid level drops down a bit, so if you top it off with it pressurized, the fluid may be overfilled.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
