Originally Posted by Bumbo
I do very little to my truck for aesthetic gains, I would think twice before going down this road because it may trigger additional expenses you might not have considered.
As an example adding bumper weight may require an adjustment in front spring rate to correctly support the weight. This means lift with the right springs to accommodate the additional load.
You mentioned you do want to start off-roading, and learning about it… If that is truly the case, you might be better suited to get sliders or skids as your first armor mod.
Yes the extra weight might trigger other expenses.
Or loose some weight by leaving the old lady home, ditching the beer cooler, take the doors off etc etc.
