View Single Post
Old 01-28-2020, 04:16 PM
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
Originally Posted by phattyduck View Post
The 2WD driveshaft has two single u-joints (not the double-cardan front joint that the 4WD's have). The rear pinion angle should match the transmission output angle - unless you put on 4WD upper links, your pinion angle should be fine with all the OEM links.
How's the driveshaft itself doing? The OEM 2WD shaft has a rubber isolator that wears out with time that causes vibrations that can only be fixed with a complete new driveshaft.
Well remember, I have what was advertised as a "3inch" lift. If the rear is lifted too high, the 3rd member is going to want to rotate downward to the ground. And you can see the slip yoke is not slid all the way into its home either.
Whenever i packed that weight in the back it brought my ass end back down, and the axle was brought closer to where it should be. (rotated back up)
This gave me two things, my yoke had better engagement with the splines on the output shaft, and it brought the pinion angle back into alignment with the transmission output yoke angle.
The rear uppers should be OEM unless PO changed them, for some ungodly reason.
Once I go back home im going to take some measurements to see how much it actually brought the ass end down.
The 2WD driveshafts are quite inferior compared to 4WD. The double cardarn and 2 piece shaft is the reason why lfited 4WD runners dont have this problem nearly as often as a lifted 2WD runner. Its pretty nice the 4WD bolts to the transfer case.
I found another thread on yota techs page where a 2WD runner installed 891's and had the same issue as me but he went different ways to fix it and never could fix it, but he also never tried adjustable endlinks, instead he was just changing the length of his shaft.
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
