Also keep in mind that a number of features back there are interlocked - if the rear window is down (or the rear door ecu thinks it is), then the window wiper won't work. If the rear ECU thinks the window wiper isn't parked, it won't allow the window to work, etc.
Also, there is a confirmation switch in the door lock on the back door that will keep the wireless beeper from beeping if the lock doesn't get set. Lots of complications back there...
Check all the fuses!
Verify power locks operate the rear door locks
Check rear window with key
etc.
Report back as much detail as you can.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
