View Single Post
Old 01-31-2020, 02:53 PM
Elite130 Elite130 is offline
Elite130 is on a distinguished road
To answer your questions. No. There is no brake controller preinstalled from the factory. However, that said, the wiring is all there. The wiring is all there from the 7-pin connector at the hitch all the way to the front under the dash near the driver's left footrest. All you need to do is order yourself a brake controller (I suggest a Prodigy P3) and the pre-fabricated harness (Brake Controller Install Harness for 2016 Toyota 4Runner | etrailer.com). Then all you need to do is mount the brake controller, connect the harness to the brake controller and then into the plug under the dash and you are good to go. I believe the required relay in the engine bay fuse block is already there. This is what I did and was very easy.
2016 4Runner Trail Premium...Delivered 1/22/2016. Mods: OME Lift, Husky WeatherBeaters, Interior/Exterior LED, Console Vault, AVS Hood and Side Window Deflectors, 275/70/17 BFG KO2, Rigid Dually SAE fog lights, Rigid 20" E2 Hyperspot, Garmin Dash Cam 55, ToyTec HIDs, Aiden James Saber Pro LED high-beam bulbs.
Elite130 is offline   Reply With QuoteReply With Quote
