A little out of order… but before adding any electrical accessories I wanted to come up with how the wiring was to be done or it was gonna turn into a rats nest real quick. Looked at the Bluesea stuff but really liked how clean the Bussmann setup is, incorporating the fuses and relays in one enclosure, so clean. I liked the idea even more after finding this 6 part tutorial at bodenzord.com.
DIY Bussmann RTMR Fuse Block, Part 1 – Introduction | Bodenzord He even sourced and linked the parts needed!
I did make a few minor changes, but basically straight up copied that setup.
Also, did a DIY power tray out of aluminum.
Bottom with everything wired up
Installed
Had to come up with a place to mount the switches and the sunglasses holder wasn’t seeing any use
I had leftover aluminum from the tray, so I bent it up, painted it black and mounted it with some screws through the sides.
pic from the windshield side, you can't see the gap when it's installed in the headliner.
Can’t claim credit for this idea, saw it here:
Overhead 6 switch panel - Toyota 4Runner Forum - Largest 4Runner Forum
2007 SR5 4WD Nautical Blue --
Build Thread
