Installed Victory 4X4 BLITZ Aluminum Bumper with HF APEX 12,000 lb Winch
Installed a Victory 4X4 BLITZ Aluminum Bumper with HF APEX 12,000 lb Winch this weekend.
I really like the bumper.
The winch just barely fits but places pressure on the power steering return line and if you don't mind it touching the grill.
I had to remove the control box to install the bumper with the winch drum attached and then remove the hood latch, horns, and center support bar to reinstall it on the winch..
I have ordered some high temp split loom to help with the line\winch contact..
I can reach the control lever through the opening in the bumper but may need to remove several sections of the grill to access to remote switch and control cable port...
I may remove the light bar filler panel so I can see the winch drum...
2017 Toyota 4Runner TRD Off-Road Premium, Dual Battery with Blue Sea Switch, 2" Lift with Eibach Coilovers & ICON 2" Rear Springs, GOBI Stealth Cargo Rack, BFgoodrick KO2 Tires, weBoost Drive 4G-X OTR 470210 Cell Phone Signal Booster, Goose Gear Rear Plate, ARB CKMTA12 On-Board Twin Air Compressor, ARB Differential Breather Kit, Yaesu FT-891 & ICOM IC-2730A Amateur Radio Transceivers, Victory 4X4 Blitz Bumper and HF APEX 12,000 lb Winch.
