Originally Posted by brillo_76
If extended crank issue occurs. I would check the fuel pressure at the rail. Make sure your fuel filter is good. Granted this is after a through check of ignition system as well.
had installed brand new OEM fuel pressure regular, denso fuel pump, and OEM fuel filter beforehand. as i said i diagnosed and repaired the issue
