View Single Post
Old 02-04-2020, 10:37 AM
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
All pro UCAs questions
I have a 3inch OME lift on my 99. I extended sway links and pan hard as well. My UBJ appear maxed out now. I also get rub on the control arms at full tilt.
I'm chasing a clunk which I believe is either my ball joints maxed, or sway bar rubbing.
Either way with the rub I need to change my UCAs.
So my question is anyone run All Pro UCA with 285s, does it correct the rub issue once alignment is done?
Also will moving to the uniball design correct the ball joint maxed out issue?
Thanks in advance.
G_Raw is offline   Reply With QuoteReply With Quote
