Originally Posted by coreynw
Somehow I missed these replies a few weeks ago. Thanks
@ ElectroBoy
and
@ rigtec
! I took the door apart and traced the wires all the way to the transition to the body without any loose connections. Indeed as
@ ElectroBoy
noted, there appears to be 12v coming from both red and pink at the light fixture at this point.
Hi Corey,
A remark you made stood out for me so I wanna address it here! You said:
"Thanks
@ElectroBoy
and
@rigtec
@ElectroBoy
noted, there appears to be 12v coming from both red and pink at the light fixture at this point."
Usually, whenever you see/find juice-(
POS) coming from the
NEG line... it's coming "THROUGH" your
'Load Circuit' on it's way to the ground pole, e.g. when you feed a lamp 12V, after it hits the filament, it still has yet to reach the GND while still
HOT!
So whenever I need to cut a BAD/ Mis-guided GND circuit because the GND pole/junction has failed, and I can see where it's "supposed" to go, like an ECU, but I still have NO GND, when I cut that wire to re-route it to another GND point, I know I have to 'CAP IT' because "It's Still Live!" ...Follow...?
"Best!"
rig!
