Originally Posted by vipergrhd
Being a wrecked vehicle did it get hit from the rear or roll over? It could potentially damage the axle tubes and axle but the good thing is you can salvage the rear locker unit as long the motor is working I am not too worried about the harness you can buy a plug and play harness from Low Range Offroad or 12 Volt guy. It should be an easy unit to drop with basic tool just cut the brake lines and disconnect the harness.
Looks like it got hit in the rear, Im planning on calling again to clarify theres no axle damage. If so ill just pull the 3rd and have to modify the stock axle carrier. This will be interesting no doubt.
