Originally Posted by rideexileex
I'm too late to the party... This would be the ideal way to wire it in my mind... no relays needed. Both maps lights come on when a door is open, and still work independently when the doors are closed.
You missed the part where the map lights are wired opposite of the diagrams in sunroof 4Runners. So, swap pins 1 and 3 - then try your diagram again. That's why the relay is needed.
Your diagram will probably work just fine on the non-sunroof 4Runners... but would still have to be verified that the switch is on the ground side, not the power side of the circuit.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
