Originally Posted by rideexileex
BTW - in the diagram before mine last posted, sorry to be critical, but you'll never be able to work the map lights independently, the relay would only need a jumper between 86 and 87 and a single tap to the L-Y wire or any +12V (no independent wires), nor would a diode be needed.
No offense taken, I was being lazy on the diagram for the map lights. I love the discussion here as I consider myself an amateur wiring person. See
phattyduck
's comment regarding where the switch is (ground side vs power side), the last diagram I posted has them positioned correctly for the sunroof models. Your point for jumpering 86 and 87 to L-Y is an excellent one.
