Originally Posted by gamefreakgc
You just described my 4Runner from 3 years ago!
Two separate things. The hard shift into 3rd is completely normal. If it bothers you, switch to full synthetic trans fluid and that goes away. The delay is just because of fluid temp and it needs to warm up more.
Slowing to the stop, it's like a humm/grind/whirr coming from the rear correct? Most likely it's your rear diff bearings on their way out. Not an urgent fix, just an annoying one. You only hear it when you are slowing down with 0 throttle right?
Ah okay as long as my 3rd gear is fine I'm happy.
Well I don't think that is the same kind of sound. This is a quick "shift" kind of sound vs a long drawn out sound if that makes any sense. Like a clunk sound maybe? I'll try to get a recording of it. She does not always do it.
